Hello everybody!
I have an issue with my cnc machine. When i turn on the power supply i can't start imediatly my job because apears an alarma that say:
"1038 ENERGY RECOVERY ,MODULE NOT READY"
How i can fix that?
Thanks a lot!
Hello everybody!
How i can fix that?
Thanks a lot!
The alarm shown is generated in the PLC (ladder) as indicated by the alarm number (1000 series). It will not be found in any Fanuc manuals. You will need to check the OEM documentation or look in the ladder for the cause.
Its possible someone in the forum has this machine and my be able to help.
Thanks for you help oetkbyentc! I'll check machine manual.
Does anyone have the same problem? I've seen the machine manual but I haven't found anything. To start my work, I have to wait a long time to reset the alarm, and i don't have way to connect me to the PLC. Thanks a lot!
We can hope the OEM has used simple logic for the machine.
To start
Check to see that the OEM has the ladder set to be displayed.
If they do
Go to the PMC status screen.
Look for "A0".
Start scrolling down looking for an "A" address that is high ( a 1).
When you get through the area go to the ladder.
Search (W SRCH) for that "A" address' that were high.
Hopefully they have used symbols make sense to the alarm you are seeing.
Check the logic to see what is triggering the fault.
