Re: AASD-30A-v6.2 Servo Drive wiring to ESS and MB3
If you have not already purchased the servos, you might want to reconsider the size. 1.8kW is way overkill for that PM833TV machine, unless you are talking about the spindle drive. 750W is more than adequate to run the axes on that machine, my Haas TM-2p only has 1kW servos on the X and Y axis, and my 10x54 knee mill has 750W servos and I have never run out of power.
As Craig says, those AASD-30A units would not be my first choice. Documentation and support is worth every penny you pay for it.
You might look at what DMM Tech has to offer https://store.dmm-tech.com/ Good, readable documentation, and great support
Also the Automation Direct SureServo2 (Delta) line is also worth a look, https://www.automationdirect.com/selectors/sureservo2
As well as the lower cost LS Electric servo line from Automation Direct https://www.automationdirect.com/selectors/ls-servo
Automation Direct has great documentation and great tech support, as well as free 2 day shipping
I have used both the SureServo2 and DMM products and can recommend both. And I just ordered 2 of the LS Electric 750W units from Automation Direct.
Jim Dawson
Sandy, Oregon, USA
