585,973 active members*
4,151 visitors online*
IndustryArena Forum > CAM Software > Vectric > Rough edges on one side when 3D carving
    Mar 2010
    162
    https://youtu.be/x38OLicVF38
    Any idea what might be causing the rough edges Illustrated in the video above? I tested my X & Y, by having it cut some circles and straight lines of different lengths and diagonal lines, and all of that came out perfect, so I'm going to test my Z today, I don't think I'm missing steps because the heighth is correct on the parts it's not like one part is a little shorter than the other or part way through it's cutting at a different height than before, it's just those scalloped edges.
    Thanks!
    1224
    Re: Rough edges on one side when 3D carving
    It looks like something is moving or flexing,perhaps the whole workpiece because the bottom looks quite thin..Without more knowledge of how the piece is being held on the machine it isn't easy to understand the possible cause.The top surface looks good so if the sides are vertical,how about leaving a small amount on the outside to clean off with a very light profile cut?
  1. Laser cutter producing dotted line cuts edges are very rough even when cut completely
    By worldspawn in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-29-2020, 05:13 AM
  2. Rough / Jagged Diagonal Edges
    By cobra514 in forum FineLine Automation
    Last Post: 10-02-2017, 01:32 AM
  3. V25 Face, Side Rough, Open Pocket
    By aldepoalo in forum BobCad-Cam
    Last Post: 06-27-2013, 11:44 PM
  4. Selecting which side of geometry to rough mill.
    By AiR_GuNNeR in forum EdgeCam
    Last Post: 10-19-2011, 12:54 AM
  5. Getting Rough edges on Taig milling aluminum, please help
    By b0gh0s in forum MetalWork Discussion
    Last Post: 01-08-2006, 01:36 AM
