585,967 active members*
3,903 visitors online*
IndustryArena Forum > CAM Software > MadCAM > V carving text on circumference of a cylinder
Results 1 to 10 of 10
    Sep 2006
    8
    I am trying to v carve (engrave) text on the circumference of a cylinder using a 90 degree V-bit (or 45 degree taper tool in madCAM). The toolpath generated does not appear to move in the Z axis, only X and A.
    It does appear to work on a 2D test, as demonstrated in the tutorial video, but not around a cylinder. Has anyone figured out how to do this?
    Thanks in advance!
    May 2013
    261
    Re: V carving text on circumference of a cylinder
    Which tools are you using , it seems that you have Z movement above the surface for rapids but not below the surface for cut movements ?
    Sep 2006
    8
    Yes, you are correct...I do have Z movements above the material but not cut movements. I am using a 45 degree tapered tool (V bit)
    May 2006
    343
    Do you have a negative value for your Z depth cut below the surface?
    May 2013
    261
    Sorry I meant to ask which tool path your using in madcam , are you using cut between 2 curves or one of the other 3D cut along curves ?
    If your using cut along curves you can enter a negative value for. Curves on the surface or put your line at the bottom of the cut and enter a positive value .
    Hope that helps
    Sep 2006
    8
    I'm using From Boundary Curves...I'm following the info in this tutorial video and applying the same strategy to a cylinder. The flat test appears to be doing what it should but the rotary doesn't.
    https://www.youtube.com/watch?v=ykLb...nnel=madCAMcnc
    May 2013
    261
    So it looks like from the way the cutter rapids in Z 90 to the surface your using 4 axis between curves , when I use the same set up I get below surface cutting .
    But I do not see how one would control the depth other than the cutter will try to plunge to have to 2 sides of the taper always touch the outside lines thus Z height should change upwards where the lines are closer and downwards with wider lines
    The only odd thing I get is it almost crashes rhino to use the simulator
    I will try to find time later to play with it more
    May 2006
    343
    Is your origin and or cplane at Z zero? Try raising it to the depth you want your cutter to go
    Sorry, 4th axis part. That doesn't apply. Madcam website there is an update for v carving
    May 2013
    261
    One thing I noticed if the cutter is too wide it will not drop the Z height much , try and create a tool in madcam tool library that has a narrower cutter angle and see if that helps
    such a informative
  1. V25 : 4 axis wrapping for text on a cylinder
    By aldepoalo in forum BobCad-Cam
    Last Post: 11-29-2013, 06:33 PM
  2. Text engraving on cylinder side
    By JOE OMNI in forum Okuma
    Last Post: 05-12-2012, 07:57 AM
  3. Wrapping Text Around a Cylinder
    By aus10eww in forum BobCad-Cam
    Last Post: 04-12-2012, 08:41 PM
  4. drilling on cylinder circumference
    By merraton in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 08-26-2011, 08:09 AM
  5. Replies: 12
    Last Post: 05-15-2011, 10:55 PM
