586,009 active members*
4,878 visitors online*
IndustryArena Forum > CAM Software > Alphacam > programming Hurco vm20 with Alphacam
    Cool programming Hurco vm20 with Alphacam
    I have a Hurco vm20 that is programmed via conventional means, but i have a job that would benifit greatly from being programmed with a nc program through Alphacam. Has anyone done this through Alphacam and if so did you require a specific post for the machine or was there a standard one with alphacam that worked?
    Thanks greatly
    Mar 2022
    28
    Re: programming Hurco vm20 with Alphacam
    Hi
    Alphacam has postprocesor for Hurco, I wrote it, but in alphacam default postprocessors you can't see it.
    If you can send me some ALphacam file I can output it and I will send it back to you for check if it pass to your machine.
    Regards
    Pavel
  1. programming hurco vm20 through alphacam
    By ukprogrammer in forum HURCO
    Last Post: 12-16-2021, 09:23 PM
  2. HURCO VM20
    By slider.1978 in forum HURCO
    Last Post: 02-15-2014, 12:25 AM
  3. Hurco VM20 Winmax post?
    By jolson89 in forum GibbsCAM
    Last Post: 03-24-2012, 02:58 PM
  4. hurco vm20
    By maximas101 in forum HURCO
    Last Post: 12-03-2010, 04:59 AM
  5. Hurco VM20 ???
    By nevron in forum HURCO
    Last Post: 08-22-2009, 06:53 AM
