585,760 active members*
3,689 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Spindle not orientating following a low RPM operation
    May 2013
    160
    I've been having a problem with my DM-2 not orientating following a lower RPM tapping operation, but today I had it do the same thing on a drilling operation where my RPM was only 600 rpm.
    What happens is the spindle doesn't orientate and then it does a tool change the tool drops because the spindle isn't orientated.
    I had already posted this issue a few weeks ago, but now that it appears it has more to do with the RPM verses the tapping operation I figured I would create a fresh new post.
    I'm guessing there must be a parameter setting that's causing it not to orientate on a low RPM ?
    I don't know what the breaking point is as far as how low the RPM needs to be for this to happen, but I just tried the drilling operation with an RPM of 1,000 and it worked fine..... ( so it must be any RPM lower than that )
    Any thoughts or suggestions ?
    Kent
    15362
    Re: Spindle not orientating following a low RPM operation
    Quote Originally Posted by kentdesautel13 View Post
    Kent
    What kind of drilling operation where you doing to need 600RPM?
    Spindle orientation should not have anything to do with the speed you have been running at, check the spindle encoder.
    Mactec54
    May 2013
    160
    I was just using a chamfer tool to go strait down into a hole I had drilled to create a cutout for a screw head.
    I realize now that the RPM was too low for this operation.
    The machine works flawlessly on all of the tool changes, but only has issues on these low RPM situations.
    I will fix that by making sure I don't put in a low RPM going forward.... but it would be nice to figure out whats causing this glitch.
    I called my local haas dealer when this first popped up on a tapping operation ( also at low RPM ) and he had me add a couple of lines of code after the tapping operation that forced the machine to change RPM's before the tool change and the fixed the issue.
    he asked me what version of software I had and he made the comment " that should have been fixed with that version " which left me with the impression that it's a known issue software glitch.
    This is the line of code he had me add at the end of the tapping operation that "temporarily" fixed the issue
    S100 M3
    G4 P500
    Where it got left was that we were going to have the software reloaded in the machine.... but now after running into this today with a simple drilling operation I'm thinking it may be a parameter setting.
    Like I say, I will just make sure all of my RPM's are at least 1,000 going forward and that will fix the issue.
    15362
    S100 M3
    G4 P500
    There was something with rigid tapping that 800 RPM was the slowest speed to be tapping at, so I have never run below that for rigid tapping
    Even 1000 RPM, what size Drill where you using at that speed.
    Mactec54
    May 2013
    160
    I am using a 1/4-20 tap in 1/2" thick aluminum. The hole is all the way through
  1. Spindle Rpm too low
    By robjeffking in forum Avid CNC
    Last Post: 12-02-2020, 05:02 PM
  2. chinese spindle at low rpm?
    By gianluca70 in forum Spindles / VFD
    Last Post: 10-12-2015, 05:16 PM
  3. Low RPM spindle trouble on SL-10
    By micro-tech in forum Haas Lathes
    Last Post: 06-11-2011, 01:57 PM
  4. Low RPM Spindle
    By kolias in forum DIY CNC Router Table Machines
    Last Post: 03-04-2011, 06:40 AM
  5. Low-speed (rpm) spindle wanted!
    By ilya in forum DIY CNC Router Table Machines
    Last Post: 01-13-2010, 10:52 PM
