585,930 active members*
3,869 visitors online*
    Aug 2008
    406
    ELOX / FANUC O WIRE EDM
    Had a battery alarm replaced the batteries and alarm will not clear .It appers as the two wires on the bottom battery box have become cut ??? Machine was working the night before...Machine is a elox O wire edm with a OM Fanuc controller .It uses AC servo motors and drives . Can any one help .Need wire schmatic of lower battery box . Had a 336 346 alarm 0 voltage absolute pulse encoder alarm for u and v axis . I made the machine think its a two axis machine to run parts but need to fix this can anyone help ?
    Aug 2008
    406
    Re: ELOX / FANUC O WIRE EDM
    Problem solved.
    Dec 2005
    594
    Care to elucidate?
    Mark
    Aug 2008
    406
    I found drawing for a O OO O -MATE and found where to connet the borke wire .
  1. ELOX/FANUC O WIRE EDM
    By gabedrummin in forum EDM Discussion General Topics
    Last Post: 02-22-2022, 05:17 PM
  2. Wire edm Fanuc Elox Series L
    By glowplug in forum Fanuc
    Last Post: 10-20-2014, 12:23 PM
  3. Elox/Fanuc Tape Cut Wire EDM
    Last Post: 12-17-2012, 03:50 PM
  4. Elox/Fanuc Wire EDM
    Last Post: 06-06-2012, 07:01 PM
  5. ELOX WIRE EDM FANUC OM CONTROL
    Last Post: 10-11-2010, 03:46 PM
