585,733 active members*
4,968 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > Polls > Question, electrical noise interfering with stepper moter operations
    Hi, I built a DYI CNC router and everything works great until I turn on the router. That is I can run cnc programs and they run great with the router motor not running. I turn on the router motor and the run program or just movement with jog and the movement will pause over and over again until the controller locks up and I have to disconnect the USB connection. I reset the USB connection and it works again. The wiring to the router motor is shielded but the stepper motor wiring is not. Any thoughts??
    nvcm6v2.1 usb controller, nema 23 motors
    24220
    Re: Question, electrical noise interfering with stepper moter operations
    What is the nature of the router motor?
    Have you followed recommended earth grounding techniques, including bonding any moving mechanisms such as a moving gantry etc
    Albert E.
  1. RF interfering with stepper motors
    By Bradnicent in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 12-17-2018, 08:23 PM
  2. Electrical noise emitted by new stepper drives
    By johnd_issaquah in forum Stepper Motors / Drives
    Last Post: 06-14-2016, 06:54 PM
  3. Stepper moter sizing and power requirements
    By jwest in forum Stepper Motors / Drives
    Last Post: 01-15-2009, 08:52 PM
  4. stepper setup, Electrical noise ?
    By veteq in forum Stepper Motors / Drives
    Last Post: 02-08-2007, 05:31 AM
  5. hpgl and stepper moter control
    By Jan in forum Uncategorised CAM Discussion
    Last Post: 01-08-2004, 07:00 PM
