585,992 active members*
5,344 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > VF 1 Cutter Comp for tool diameter
    Jul 2011
    Question VF 1 Cutter Comp for tool diameter
    I have a Haas VF1 and just loaded a .5" SQEM that had a actual dia. was .5024. All my parts are coming out to small on the OD. I am not sure how I compensate for that over size. If there is a process I need to go through on my offset page or not. Looking for some direction. I have turned cutter comp on in my posted file using G41 but not sure if that is all I need to do.
    There are a few lines of the code for this tool
    G20 G40 G80 G90 M09
    G103 P0
    T02 M06
    M01
    S10000 M03
    G43 H02
    (msg,watchforair)
    M08
    M83
    G00 G90 X.135 Y-.9827
    Z.2631 M08
    G01 Z.0731 F30.
    G41 Z-.0269 F15. D00
    X.1352 Y-.6318
    X.1163 F30.
    G02 X-.0001 Y-.6177 I.0057 J.5328
    Not sure if the D00 is correct or not. I use a probe to set all my tools length and diameter.
    Any direction I can get would be greatly appreciated...
    Steve
    Dec 2008
    3109
    Re: VF 1 Cutter Comp for tool diameter
    Ideally, most program using the tool number(Tx), matching the tool length offset number(Hx), matching the tool dia/radius offset number(Dx).
    If on some machines this is not possible, then the one that is dropped is the diameter offset number (which may be staged a constant number higher ie T1 H1 D31)
    D00 is a non editable offset that is permanently set to zero.
    This D(number) needs to be edited to another number, and then that number field can hold your tool adjustment.
    It looks as if you program tool centreline paths, if you do, then a +ive number makes the tool stay further away, -ive makes it pass closer
    Some machines a diameter input, some a radius value. Try inputting a value of +0.0024, if it cuts correct size, your machine takes a diameter value,... halve the value if your part is oversize.
    15362
    Quote Originally Posted by Steven E View Post
    G20 G40 G80 G90 M09
    G103 P0
    T02 M06
    M01
    S10000 M03
    G43 H02
    (msg,watchforair)
    M08
    M83
    Z.2631 M08
    G01 Z.0731 F30.
    X.1352 Y-.6318
    X.1163 F30.
    Steve
    D should be your tool number D2, normally you can't activate cutter comp with a Z axis move should be a X or Y move
    Mactec54
    Aug 2009
    1573
    ..."Part Contour" programmed path or Net example mactec posted above is the way to do it. Then, all Diameter Offset (Dxx) settings would be "+" and actual Tool size. The Part Contour can be a Subprogram and just by changing the D Offset call you can rough and finish with different Tools or same Tool (using variable D) and only write it once. (big time saver in the old days) There are some limits like using an Endmill bigger than the smallest Radius in Pocketing cuts.
    Jun 2007
    46
    Steven: First thing I would recommend is to recalibrate your probe and toolsetter. .5024 diameter seems a little too far out of what should be nominal. Anytime our toolsetters (Renishaw) get beyond .001 on quality made tooling, we recalibrate.
  1. tool wear/cutter comp
    By jbranting in forum Haas Mills
    Last Post: 12-19-2017, 10:30 PM
  2. Replies: 5
    Last Post: 11-27-2014, 08:28 PM
  3. Using tool diameter for cutter comp
    By intenths in forum Surfcam
    Last Post: 02-20-2014, 03:32 AM
  4. Replies: 2
    Last Post: 02-11-2014, 01:17 PM
  5. Can I adjust cutter comp diameter within a program?
    By davereagan in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 11-20-2007, 05:12 PM
