585,708 active members*
3,899 visitors online*
IndustryArena Forum > MetalWorking Machines > Kitamura > Kitamura clamp pressure vs drawbar stroke range
    Nov 2021
    I've got a Kitamura 500i and we've sent the spindle out for repair because of a crash. My question is how much pressure should the drawbar create when clamping a Cat-50 holder? My check of this was around 3300 psi on another Kitamura but the company repairing the spindle is saying the pressure they're seeing is around the 7,000 psi range. Measuring the stroke of the drawbar from the spindle face to the collet bolt inside the spindle gives me a range of .488. Does anyone have any specifications of the correct drawbar clamp psi and stroke range? Thanks in advance for any help.
    Greg
    Mar 2009
    1982
    Re: Kitamura clamp pressure vs drawbar stroke range
    Check the architecture of your machine. I guess, the clamping force is created by spring, it could be ( 5 ... 15 ) tons. Hidraulics used for unclamp only
    only guessing, don't know for sure.
    So, you can reduce the pressure till unclamp failure and double the pressure then.
  1. Kitamura Mycenter H400 - tool clamp issue
    By shas595 in forum Kitamura
    Last Post: 11-27-2018, 07:27 AM
  2. Haas Mill drawbar / tool clamp probem
    By metalmansteve in forum Haas Mills
    Last Post: 02-17-2011, 01:50 AM
  3. Low drawbar pressure, what do I do?
    By bob1112 in forum Haas Mills
    Last Post: 08-01-2008, 09:15 PM
  4. Replies: 10
    Last Post: 11-04-2006, 01:12 AM
  5. Hitachi spindle clamp pressure
    By pieface in forum Vertical Mill, Lathe Project Log
    Last Post: 02-10-2006, 03:27 PM
