Originally Posted by
boydage
LS Lg5 2.2kw VFD, 3 phase, 0-400hz to run a 1.5kw Squirrel Cage, 3 phase 50hz, 1400RPM, motor. Is to be installed onto a small lathe to upgrade the torque.
Ive setup a few high RPM spindles, the last one a 6kw 1000hz 24000RPM ATC. I cant say I have setup a 50hz motor before. This one is 1400RPM. I was just going to set the VFD to 50hz but have read I can double that or even a little bit more yet still achieve a good strong speed controlled motor.
Am I wrong? Reading into it, if I increase the frequency to say 100hz and feed it into my motor it will run at 2800RPM, still be able to cool, have torque, and be no way too fast for the bearings. Please tell me if I am wrong on this? I would expect to be able to drop the speed with the VFD to lower the rpm below 1400 by a tad until I cant cool but going faster is possible huh?.
Have I got this wrong? Keen to hear from someone familia with this kind of setup please. Thanks
