motor fault (0x 1) XA Drive 1-faulted Axis 0 3000_545_3422_XA Count 9: Drive is OK Safety stop basis: Bad hall
I keep getting this message at startup. Any thoughts
This message seems to suggest you have a loose or perhaps a Hall effect homing sensor that is going bad.
This happens because the controller starts to home and sees that the home sensor a hall effect sensor has fired meaning it is already there to it stops motion. Check the hall effect sensor on the X axis. It is either bad or it is loose and near a piece of metal causing the problem. They are not that expensive you could order a new on and you would be in good shape.
Russ
