585,748 active members*
3,592 visitors online*
IndustryArena Forum > MetalWorking Machines > Bridgeport Machines > Bridgeport Interact 720 Z Axis Motor Removal
    Jun 2011
    61
    Hi folks , I need to move out of my old workshop and into a new ,and warmer one ! And I need to remove the Z Axis Fanuc motor on top , a damn heavy piece of metal ( it dont fit under the door frame . I did this when I bought it 15 years ago and cant think how the hell I did it ! Is it just the 4 screws ,bolts , out and supprt the spindle, lift and crack it off the shaft ? I thought I would ask a grown up before I do the other thing ! All the best stay safe all you lot , Harry
    Aug 2009
    1570
    Re: Bridgeport Interact 720 Z Axis Motor Removal
    ..most likely has a Flex Coupler from motor to ball screw. Finger type
    Jun 2011
    61
    Hi there ,that was ther first clue the second was from Carrie at Repair Zone ,and this is what I found !! 12 of the smallest screws painted over and hiding a thin metal cover ! And heres the coupling ! Job done ! Thank you for the tip Harry Attachment 476670Attachment 476672Attachment 476674Attachment 476676Attachment 476678Attachment 476680 REPAIR ZONE
  1. Bridgeport Interact 720
    By Monte Godwin in forum Bridgeport / Hardinge Mills
    Last Post: 05-14-2022, 01:26 PM
  2. Bridgeport 720 Interact
    By beemergb in forum European Club House
    Last Post: 06-08-2014, 04:03 PM
  3. Bridgeport Interact 720
    By beemergb in forum Bridgeport / Hardinge Mills
    Last Post: 04-08-2013, 08:13 PM
  4. bridgeport interact 720
    By foseguera in forum Post Processors for MC
    Last Post: 01-18-2010, 05:04 AM
  5. Bridgeport Interact 720 VMC Axis fault error
    By FLjoyride in forum Bridgeport / Hardinge Mills
    Last Post: 01-07-2010, 01:55 AM
