585,744 active members*
4,991 visitors online*
    Sep 2017
    I Use Planet CNC and it Works Great
    Hi friends!
    Have a MK2/4 from 2010-2011 aprrox... All works fine, but Im feeling that want a bit more... For example: Sometimes I use artcam software for 3D, and controller works not fine. a lot of acceleration and deccelerations, stops. Curvy is broken and machine vibrating as beast. But if I use powermill software all good. Second issue - time of machining... I dont know why, but chineese A11 or Purelogic PLMC-e4 machining time is smaller. Third issue - when I mill circular parts from alluminum I can see flats and vertex, co it is not circle, it is multycorner figure.
    Why MK3 is better than MK2 answer me please! I m think for upgrade, but not ready for risk, maybe purelogik plmc-e3 | e4 will be better than MK3
    Thank you!
    Mar 2017
    1304
    Re: I Use Planet CNC and it Works Great
    Please send your g-code and settings to our email: support (at) planet-cnc .com
    I will check why there are vibrations and I'll estimate cutting time with Mk3.
    Mk3 with TNG is much more advanced.
  1. I Use Planet CNC and it Works Great!
    By CNCArtD in forum PlanetCNC
    Last Post: 11-06-2018, 04:37 PM
  2. CNC 3020T-DJ, Works Great, Couple SMALL Questions...
    By kb0nly in forum Other Machine Topics
    Last Post: 09-17-2014, 03:03 AM
  3. I made a cnc router table, works great, but is it possible to auto probe a part?
    By skyguynca in forum DIY CNC Router Table Machines
    Last Post: 11-28-2013, 02:08 AM
  4. my cheap cnc plasma cutter (650.00) works great
    By vdoug in forum Uncategorised MetalWorking Machines
    Last Post: 01-05-2011, 04:22 PM
