585,906 active members*
4,083 visitors online*
IndustryArena Forum > CNC Electronics > CNC Machine Related Electronics > Yaskawa vector drive wiring question
    Jun 2005
    20
    I am doing a change over on my Laguna SmartShop 2 from B&R control to PC based. I am looking at the vector drives for my Vacuum pumps and have a question about their wiring. The nameplate on the vector drive indicates they are three phase. But the wiring coming into my machine is single phase and the L2 is looped back up to the L3 to feed the third phase, which is confusing me. I have removed the L3 on the vector drive and the pump still runs.
    The machine was bought as a single phase unit in 2017 and I have owned it since new.
    I have been running the machine for several years with the looped 3rd phase but I do trip breakers in the summer when the pumps overheat because I am running the entire machine on one circuit. I would like to put the vector drives and pumps on their own circuit and use relays to control them and an amperage sensor to sense if they are on or off to stop a program running if they go off.
    My question is, can I run the vector drives on a single phase by removing L3? It seems to work, and I don't have true three phase power anyway.
    In the line drawing on the last picture the motor is actual the vector drive going to the motor.
    Thanks for any help.
    Matt
    Attachment 474466Attachment 474468
    15362
    Re: Yaskawa vector drive wiring question
    Quote Originally Posted by rosco View Post
    Matt
    Yes, they had it wired incorrect, but where on the right track
    Somehow got a double post.
    Mactec54
    15362
    Matt
    L1 (R) & L2 (S) should be the main connection for that VFD Drive but you should have a Jumper from L1 to L3 (T), this can cause a fault if not done this way, on some of these 3Ph VFD Drives as they have a Phase missing protection. this also helps with a little better VFD Drive performance as well. (This is only for the input AC Power to the VFD Drive)
    Need to Know more of what the VFD Drive is connected too, do you have a switch between the Drive output and the motor
    Mactec54
  1. Yaskawa SGDH and SGDA servo motor/drive wiring questions
    By rpseguin in forum Servo Motors / Drives
    Last Post: 08-30-2021, 04:57 PM
  2. Replies: 2
    Last Post: 10-08-2017, 09:37 PM
  3. Replies: 21
    Last Post: 09-04-2015, 02:36 PM
  4. Vector Drive??????
    By murphdog in forum Haas Mills
    Last Post: 12-01-2012, 12:23 AM
  5. Vector drive wiring
    By thewoodnerd in forum Benchtop Machines
    Last Post: 08-27-2011, 01:02 PM
