585,970 active members*
4,060 visitors online*
IndustryArena Forum > CAM Software > CamWorks > Changing some Post Settings
    Jun 2014
    Needing A bit of help changing a few things about the post processor for my machine. I’m working with a dynapath control. I have the UPG and NC Editor open from CAMWorks and have been using them to edit my post this far. My machine specifically only wants one G command per line.
    Instead of the normal N001G17G20G40G80 safety line
    it wants
    N001G17
    N002G20
    N003G40
    N004G80
    N005G90
    Also the same can be said about M codes, One per line.
    Not sure how to go about doing this.
    Dec 2021
    7
    Re: Changing some Post Settings
    Your section code would look like this. Each line needs to start with :T: and end with <EOL>. The <N> is for your line numbers. This is the start of tape section that has your safety line. You would do the same thing for M-codes as well. That's odd that you can only have one G code per line. I've never seen a machine like that and I've run some pretty old machines. Any other machine you can have as many G codes on one line as long as they're not from the same group. Hope this helps
    :T:O<"%4LT"rogram_number><EOL>
    :T:<N><G:17><EOL>
    :T:<N><G!:ENGMET><EOL>
    :T:<N><G!:40><EOL>
    :T:<N><G!:80><EOL>
  1. Speed settings changing upon loading cnc file from USB on Steeltailor Dragon III
    By JakobSchlobohm in forum CNC Plasma / Oxy Fuel Cutting Machines
    Last Post: 08-06-2020, 06:30 AM
  2. Avoid motor resonance by changing / increasing microstep settings?
    By Witsenburg in forum Stepper Motors / Drives
    Last Post: 12-26-2013, 01:15 AM
  3. changing default settings
    By routalot in forum Rhinocam
    Last Post: 09-27-2013, 08:45 PM
  4. Sinumerik 810M changing default settings
    By ignace in forum SIEMENS -> GENERAL
    Last Post: 10-07-2010, 05:18 PM
  5. Changing display settings
    By Stebedeff in forum Fanuc
    Last Post: 09-11-2009, 07:59 AM
