585,729 active members*
4,900 visitors online*
IndustryArena Forum > WoodWorking Machines > DIY CNC Router Table Machines > Where to start with flood cooling on a DIY CNC
Results 1 to 2 of 2
    So for my DIY router CNC (a PrintNC specifically) for better or worse I want to have a flood cooling system. My table/enclosure is partially finished welded together so it was necessary to make some slight modifications to seal it up with sheet metal.
    Basically I have next to zero knowledge on these systems but want to at least get the bulk of the enclosure right the first time and have less scrap metal to cut out in the future.
    See the video I’ve put together going my idea of a flood cooling enclosure. Check the chapters to skip around because I don’t expect anyone to sit through me rambling for 15 min.
    Are there any good defacto resources or starting places online for learning all this stuff. Good DIY examples, major components, operating, maintenance, useful setup tips in linuxcnc etc?
    Jan 2018
    1516
    Re: Where to start with flood cooling on a DIY CNC
    Exit filter to catch chips and return pipe going back into tank.
    Is a good place to start planning.
  1. Flood Cooling vs. Fog Buster
    By Ron111 in forum Benchtop Machines
    Last Post: 09-15-2018, 05:00 PM
  2. Had it with flood cooling
    By jdholbrook in forum Benchtop Machines
    Last Post: 10-24-2008, 12:47 PM
  3. My new TAIG and enclosure...also flood cooling ?'s
    By VTX in forum Taig Mills / Lathes
    Last Post: 10-16-2007, 05:22 PM
  4. MicroDrop or Flood Cooling
    By kentavv in forum Uncategorised MetalWorking Machines
    Last Post: 06-08-2007, 04:13 PM
  5. Flood cooling rocks!!!!
    By JFettig in forum Benchtop Machines
    Last Post: 09-17-2004, 11:01 PM
