584,865 active members*
4,765 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Fanuc > Fanuc 15m pallet ready not working
Results 1 to 14 of 14
    May 2021
    12
    Hi! After a ram parity error i have now re-entered all of the parameters, macros and programs that was lost. But for some reason the M60 command will not work, i have noticed that the "pallet ready" button doesn't do anything, it's supposed to light up and start the pallet change.
    Are there any settings or parameters etc. regarding this i could have missed? This worked fine before the machine was reset.
    Apr 2009
    1379
    Re: Fanuc 15m pallet ready not working
    Did you restore the PMC parameters?
    Aug 2019
    145
    A couple of things you can look at as a basic starting point.
    Parameter area 7071- 7089. Look to see if any value is set to 60. This would indicate that the M60 called a macro sub and there may be an issue there. It may also be a case where a parameter here is not set that should be.
    Confirm PMC parameter settings. There is really nothing in the NC area for M60 or APC in general (other than macro or sub) as that is 100% logic driven.
    Look in the ladder to determine where the issue lies.
    May 2021
    12
    Quote Originally Posted by oetkbyentc View Post
    M60 does call on a macro that i know works. But pushing the pallet ready button can be done whenever as soon as the door closes and a program is started. But right now the pallet ready button isn’t responding so the m60 is never completed. The macro sub program is waiting for me to push pallet ready, but that button doesn’t seem to work somehow. It worked fine before so feels like parameter/ settings related.
    Apr 2009
    1379
    You didn't answer "Did you restore the PMC parameters?"
    May 2021
    12
    Quote Originally Posted by memoryman View Post
    Yes i did. I finally got hold of the correct parameters! Might be slightly wrong as it’s for a different machine but everything seems to work except the APC.
    Nov 2007
    351
    APC needs a few things
    First Check Keep Relay on the Parameter setups and see if it has an APC selected ?
    Then check the ladders for the M60 that will let you see what conditions are required for M60 or Ready button to come on like 2nd Ref position on the control and door closed and pallet at 0 not 180 and maybe even a lock or locate switch on that front panel ?
    May 2021
    12
    Quote Originally Posted by lshingleton View Post
    I’m checking now. In the LAD there’s a few lines relating to APC. APC front k, 2APC, M-APC, Special M-APC. No idea what any of it means though, except APC of course. Do you have a clue? Thanks
    Nov 2007
    351
    Do a search for M60 whats called a W search and can you see a Keep Relay on that line or take a Photo of it ?
    Just stay on M60
    May 2021
    12
    Just stay on M60
    See pictures. Really starting to lose faith. I did notice that when changing pallets manually the pallet gets stuck, seems like X0 is not quite in the middle, might have something to do with it.
    But it’s strange because before i could push pallet ready in the middle of a program and it would light up and switch pallets on the next m60. I wonder what the button needs to be activated when pushed? Doors closed, ATC position etc
    Nov 2007
    351
    For the Pallet change to work it does it will use a G30 position
    or 2nd reference
    in MDI send it to this position
    G00 G90 G30 Z0
    G00 G30 X0 Y0
    Is the light flashing for 2nd ref position ? now try manually
    Nov 2007
    351
    Then do a W search for the R100.0 or R102,6 and see what they are for or have you a list somewere ?
    May 2021
    12
    I got hold of the original parameters from japan and it seems to have solved the problem! Thank you for your help!
    Hello,
    My memory has been erased. Can you send me these parameters to the original? I also need the 9000 programs.
    Please help me.
  1. Pallet Changer Not Working
    By camdb in forum Mori Seiki Machines
    Last Post: 03-23-2022, 09:33 PM
  2. Replies: 1
    Last Post: 02-05-2020, 05:59 PM
  3. Fanuc OMC and Fanuc 15M Macro Help
    By stang623 in forum Fanuc
    Last Post: 05-01-2016, 03:02 PM
  4. Matsuura Horiz Pallet Ready Switch Help
    By haastec in forum Uncategorised MetalWorking Machines
    Last Post: 06-22-2012, 06:27 PM
  5. Replies: 5
    Last Post: 10-17-2008, 02:15 AM
