585,759 active members*
3,956 visitors online*
    Jul 2006
    70
    pierce for center of hole
    whats best way to just get a pierce for a center of a hole?
    i'm using autocad,sheetcam, mach 3
    thanks
    bear
    Sep 2006
    113
    In Autocad, create a "point" at the center of the hole. In Sheetcam, select "Use points for drilling" in the drawing options pop-up window, when opening the dxf file.
    You'll have to put the points and circles on different layers, or exclude the circles from the dxf file. If not Sheetcam will pierce the point and then cut the hole.
    Jul 2006
    70
    thanks i will give it a try!
    bear
  1. pierce delay in Mach 2 ?
    By Redline in forum Waterjet General Topics
    Last Post: 11-13-2011, 01:58 PM
  2. finding center of a hole
    By BeerFizz in forum Mach Mill
    Last Post: 06-15-2007, 01:17 AM
  3. Pierce Delay And Plunge Rate
    By DISCONNECTED in forum Waterjet General Topics
    Last Post: 01-30-2007, 03:48 AM
  4. taft pierce surface grinder problem
    By metalhack in forum Uncategorised MetalWorking Machines
    Last Post: 11-29-2006, 09:19 PM
  5. Drilling a hole in the center of a bolt / newby question
    By stickben in forum Mechanical Calculations/Engineering Design
    Last Post: 04-30-2006, 05:07 PM
