585,581 active members*
3,789 visitors online*
IndustryArena Forum > MetalWorking Machines > Haas Machines > Haas Mills > 1998 HAAS VF-EXT Lost all Parameters. HELP!!!
    After leaving for vacation for 3 weeks, my battery died and I lost all parameters. I added the backup battery kit, so that is resolved...but now my mill is a 8000lb brick.
    Here is a list of my faults after boot up:
    102 SERVOS OFF
    201 PARAMETER CRC ERROR
    203 LEAD SCREW CRC ERROR
    204 OFFSET CRC ERROR
    261 ROTARY CRC ERROR
    205 PROGRAMS CRC ERROR
    250 PROGRAM DATA ERROR
    212 PROGRAM INTEGRITY ERROR
    149 SPINDLE TURNING
    120 LOW AIR PRESSURE
    122 CONTROL OVER HEAT
    119 OVER VOLTAGE
    I have no backup- The dead battery came on without warning while I was gone. There is no spare backup disk in the E-cabinet of this age machine. I called HAAS and they do not have backup files for my S/N. Their only solution was to send out someone for service. I'm still awaiting that quote, but I'm sure it will be expensive and out of my reach.
    Is there ANY other way I can get some of these basic parameters???
    I'm a brand new startup company and cant really afford a stupid error like this, but if someone can point me in the right direction, I'd be most appreciative. Give me instruction on setting parameters, offsets, etc. Anything.
    I've attached a couple shots of my monitor.
    Re: 1998 HAAS VF-EXT Lost all Parameters. HELP!!!
    Quote Originally Posted by reapertactical View Post
    102 SERVOS OFF
    149 SPINDLE TURNING
    119 OVER VOLTAGE
    Also, tell me if this is even possible:
    I've found another machine that is the exact model and has the same options as mine about 3 hrs away. IS IT POSSIBLE to back up to USB there and load it to mine at home? I know the exact axis offsets, spindle tool alignment, etc... will need to be altered for my machine. BUT...will it get me going?
    Feb 2022
    4
    You need to clear your RAM memory first , after that your machine will boot with very basic parameters, then you need to enter in debug mode and type VF3 or VF model that you had
  1. I have loose BIOS parameters DMU 70 V 1998 MILLPLUS V330
    By jaxxmaxx in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 05-11-2022, 10:39 AM
  2. 1998 HAAS VF-2
    By outlawind in forum For Sale Only
    Last Post: 01-24-2017, 01:32 AM
  3. 1998 HAAS VF-4 CNC VMC
    By TURBOjew in forum Want To Buy...Need help!
    Last Post: 09-06-2011, 08:42 PM
  4. Replies: 3
    Last Post: 02-03-2009, 05:40 PM
  5. parameters for cincinnati arrow 1000 (1998)
    By aherrc in forum DNC Problems and Solutions
    Last Post: 04-25-2008, 08:04 PM
