How to force a program to drive along the path ? On the left side of the drawing, place the path from Corel, on the right side of the drawing I put the actual path from planetcnc. I did not expect this Cutter diameter 3 mm.
G64 in g-code or disable blending in settings (Motion/Blend/Blend tolerance - set to 0)
Thank you for your answer. I am asking for help. How to force higher speed during the spindle lifting. It's now that, speed down = speed up. How to increase the spindle movement (only speed up) to speed from option "motors->speed-> max. speed" or "motion->speed->maximum.speed". I want to save time, I'd like speed down = defined speed, and speed up = max . speed.
You need to learn now g-code works.
Speed in feed moves is set with F word. Traverse moves use speed set in Settings/Program options. In both cases maximum speed setting is also obeyed.
Thanks. I know how it works. With several thousand lines gcode difficult to edit code manually. If that's not possible, i will go back to the old software, it is more efficient.
