585,877 active members*
3,486 visitors online*
    Mar 2018
    LOST ALL BASIC PARAMETERS
    Hi All,
    Lost all the machine basic parameters because turned off long days during Xmas & New year break.
    Machine: Dainichi F25
    Control : Fanuc OT
    year : 1989
    Please guide us to fix the machine If any one come across these problems in the past or if any one using the above machine holding parameters
    Any Help would be much appreciated.
    Regards
    Apr 2009
    1379
    Re: LOST ALL BASIC PARAMETERS
    The fundamental problem is that apparently your battery backup failed. Check the batteries and the battery holder.
    Nov 2007
    352
    Check Electrical Door Panel and see if any Parameters there ?
    Jun 2021
    25
    Do you have a parameter backup? If you don’t you’ll need to reach out to the machine builder and see if they have one on file. To get everything running you’ll need your CNC parameters and diags at least. Check the electrical cabinet, in my experience there is typically a folder/binder with a factory printer parameter sheet that should get you up and running. If you have a digital copy of your parameters, you can edit your IO parameters and input them via RS232
  1. lost all the basic parameters
    By cncgeek123 in forum Fanuc
    Last Post: 08-30-2012, 01:10 PM
  2. Enroute 3 basic lost drill centers function
    By japco43 in forum EnRoute
    Last Post: 09-22-2011, 04:04 PM
  3. TOOL settings, basic questions - parameters
    By expart in forum BobCad-Cam
    Last Post: 08-30-2010, 12:53 PM
  4. Lost parameters
    By darrylh in forum Fanuc
    Last Post: 06-09-2010, 08:02 PM
  5. Lost parameters
    By kangarabbit in forum Fanuc
    Last Post: 03-08-2009, 07:42 PM
