585,967 active members*
3,881 visitors online*
IndustryArena Forum > WoodWorking > WoodWorking Topics > Facing a long slab on a short CNC
    May 2018
    85
    Hi folks,
    I have 3 sycamore slabs about 98” long that I need to face/flatten on my 60” long CNC router. I can slide the slabs through the machine but my question is how to register them so that the top stays in the same plane when I slide it. Anyone have a trick for this?
    1224
    Re: Facing a long slab on a short CNC
    If you have a long and stiff straight edge you could set up a horizontal beam at either end outside the working extremities of where the slabs will be and a shade above the top surface.Then check for correct distance above your machine table,Slide the slab in and shim to get it parallel to the straight edge,which should be laid on the horizontal beams.Move along and repeat.
    May 2018
    85
    Quote Originally Posted by routalot View Post
    That’s more or less what I was thinking. My first idea was to lay some straight rails under the bottom of the slab and shim between the slab and the rails until it was stable. Haven’t decided how to attach the rails to the slab, I’d rather not run screws into the slab.
    I do have some long pipe clamps that could grip the slab at the ends, I doubt that they are straight enough to keep the slab surface perfectly registered.
  1. M6 macro z height issue when changing from short to long tool
    By Buoyen in forum UCCNC Control Software
    Last Post: 02-01-2020, 05:43 PM
  2. Replies: 9
    Last Post: 07-16-2018, 04:33 AM
  3. Win/DOS long and short file names - problem
    By DaveDoesIT in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-20-2012, 04:44 PM
  4. Short beam/Long beam? - Basic design
    By Pat2000 in forum Mechanical Calculations/Engineering Design
    Last Post: 11-10-2005, 05:49 AM
