585,722 active members*
4,211 visitors online*
    Dec 2021
    Bosch CC 100 Unable to load parameters
    Hello.
    I´M rebulding a old Bosch CC 100.
    I made a video.
    PLEASE some one tell me wath I´M doing wrong?
    After install the parameters file, it stays doing noting.
    I use a null modem and noting change.
    Feb 2006
    19
    Re: Bosch CC 100 Unable to load parameters
    Hi Tony,
    Is the PC handshaking via the serial cable? I seem to remember the CC100 is fairly sluggish even a low baud rates, and will pause transmission (by setting CTS low) until it processes the received data.
    I dont think the CC100 can software handshake, so try hardware handshaking using RTS and CTS, or try a lower baud rate
    Keep us posted
    Rgds
    Loko
    Dec 2021
    Quote Originally Posted by loko View Post
    Hi Tony,
    Keep us posted
    Rgds
    Loko
    Hello, Loko.
    It´s really going in the right direction.
    After trying lower baud and using a new cable. It appears to communicate.
    Now I have finally an error:
    LOAD ERROR 324 - Write Protect Memory. ( one file gives this error)
    LOAD ERROR 216 - Incorrect Data Format ( one file gives this error and others as show on the picture)
    Hi have 2 parameters files, but I´m not Shure that the files are in correct for the Wadkin 2000.
    Feb 2006
    19
    Make sure you dont use a windows editor when editing & saving the files. Use something like notepad++ and save in a text only format like unicode
    Mar 2016
    Tonyman, I have similar problems, I have sent the parameters in the past successfully but now that i changed the battery the process does not work. Can you please send me your parameter file to see if mine got corrupt in any way?
    Thank you in advance!
  1. BOSCH CC 100 M CNC
    By flaviusemil in forum Controller Cards
    Last Post: 01-03-2020, 04:06 PM
  2. Replies: 1
    Last Post: 09-16-2019, 08:59 PM
  3. Bosch CC100 Problem no load ??
    By r6_lion in forum CNC Machine Related Electronics
    Last Post: 06-28-2014, 11:34 AM
  4. Spindle load monitor on Makino MC-100
    By swarfy in forum Uncategorised MetalWorking Machines
    Last Post: 03-07-2010, 08:54 AM
  5. bosch cc 100
    By egyptmould in forum Bosch Rexroth
    Last Post: 12-08-2008, 12:58 PM
