585,949 active members*
4,068 visitors online*
Thread: Maho MH500C
    Jun 2016
    4
    Maho MH500C
    I am looking for a manual for an MH500C with a built-in rotary table. Not the control, the machine itself. A new control has been fitted. I am specifically interested in any information on the spindle gearing. The machine is equipped with an Indramat DC motor and an Indramat TRK6-4u DC drive. There are two motors for changing gears. The left motor (closer to the spindle output) is marked with three (3) colored dots, and the right motor is marked with two (2). The right shaft appears to be frozen in place. The middle colored dot (on the left) appears to be some kind of Neutral position, so I am thinking that there are four (4) gear ranges. Does anyone know what the original maximum spindle speed was? I am happy to pay for scanning or copying.
    Sep 2010
    4
    Re: Maho MH500C
    Quote Originally Posted by cncjeff1 View Post
    http://smoregrava.net/Maho/Maho_mh50...cal_scheme.pdf
  1. Error M01 in CNC 432 in MH500C
    By Renatox_ in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 09-09-2019, 10:35 AM
  2. Manual Maho 1200s and Maho 1600s
    By VPS in forum Machinery Manuals / Brochures
    Last Post: 07-09-2018, 07:10 AM
  3. Maho MH500C Spindle problem
    By georgetsag in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 07-01-2016, 04:13 PM
  4. Deckel maho mh500c
    By gaherne in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 07-20-2010, 12:38 PM
  5. Philips 432 diagnostics test? (MAHO MH500C)
    By AndreasL in forum Deckel, Maho, Aciera, Abene Mills
    Last Post: 08-08-2009, 02:40 PM
