585,719 active members*
4,194 visitors online*
Results 1 to 1 of 1
    Jan 2022
    Outputs Address Configuration
    Hello guys, i have a CPU 317-2DP working with a valves manifold Bosch (RM65M-16DP-F). All the valves are double solenoid. The configuration of the outputs address is not sequentially (Ex. Q0.0 - valve 1, solenoid 14. Q0.1 - valve 2, solenoid 14. Q1.0 - valve 1, solenoid 12, Q1.1 - valve 2, solenoid 12). I have to exchange this manifold to a Rexroth (BDC-B-DP_32). I already configure the network with it, but the outputs address is sequentially (Ex. Q0.0 - valve 1, solenoid 14. Q0.1 - Valve 1, solenoid 12). Is it possible to configure this new manifold to work as the old one without changing the program, only by configuration of the module?
    Attached is a table with the differences of the address.
    Thank you for the help.
