585,932 active members*
3,809 visitors online*
    Jan 2022
    11
    Fagor 800 T Error 99 M table
    Fagor 800T was working, then battery flat, now replaced, now won't move.
    Get error 99 Parity error M table..??
    Think that means codes missing or corrupted.
    I can display codes but have nothing to compare them to. ??
    I have read through manuals and this and other forums.....difficult to get details about actual codes.
    In the manual it says M41 is 0100 0001 which seems simple is is 41 in BCD.
    But then on another page it gives other codes for M41 with a long string of 1s and 0s for activating and deactivating the bits...
    I find it difficult to understand this coding or conversion.
    Is the user meant to build the M table from working out the codes manually and entering or is it possible to get a generic list in a file to download and only edit the ones that need changed.
    Is there a common or general list somewhere that would get the machine going again...???
    Sep 2022
    Re: Fagor 800 T Error 99 M table
    We have a Fagor 800m with the parameters backed up in photos. I'm not sure how useful they will be to you but If you need them please let me know. and Yes i know i'm replying 9 months after your post
    Regards, Ned
    Sep 2009
    99
    I have an 8025T where I am having the same error- Error 99 Parity Ms. Is this relating to the PLC? Do we need to restore it from the EEPROM? I am unable to find much information on this unfortunately
    Any help on how to resolve this issue would be most appreciated.
    Best regards
    Jaideep
  1. fagor 800 TG-I
    By coyote06 in forum Fagor Automation
    Last Post: 12-17-2020, 04:44 AM
  2. Fagor 8020 tgi
    By rosli in forum Fagor Automation
    Last Post: 08-08-2018, 08:49 AM
  3. AJAX premier lathe fagor 800
    By aventtini888 in forum Fagor Automation
    Last Post: 04-30-2016, 06:00 PM
  4. Fagor 800-TGI
    By mojo-7 in forum CNC (Mill / Lathe) Control Software (NC)
    Last Post: 10-29-2015, 08:02 PM
  5. Fagor 800 T
    By outctrl in forum Fagor Automation
    Last Post: 08-22-2014, 02:31 PM
