585,712 active members*
3,788 visitors online*
IndustryArena Forum > MetalWorking Machines > Shopmaster/Shoptask > Extended tailstock upgrade for 1720xmtc
    Mar 2007
    6
    Hey all, longshot here but thought I'd ask. My machine is a 1995 1720xmtc. I have the original tailstock but I think the travel is only a couple inches. It looks like on next-gen machines the tailstock travel is around 4"? Not sure. Anyway, when turning with a center I have to use a 4" extender to reach over the saddle - not the best for rigidity.
    Feb 2009
    281
    Re: Extended tailstock upgrade for 1720xmtc
    That's an issue with all the 3 in 1 machines because of the width of the milling table. I think the next generation Eldorado after yours had the longer tailstock travel. I have a vague memory of someone who made an extension to the rear of his tailstock and then fabricated a new barrel and screw, but not sure if it was on this forum, You tube or somewhere else. Maybe do some searching around.
    Mar 2007
    6
    That is exactly what I've been mulling over. I started to design an extension but thought to try this forum before I get started fabbing.
    May 2016
    15
    The short travel is a pain for drilling. However my 1720 XMTC is now full cnc with a multifix tool post so I will be able to do this when I get the right tool holder. https://youtu.be/eAXqEfCr5jI
    Sent from my SM-G990U using Tapatalk
  1. Collets for 1720XMTC
    By stanger1953 in forum Shopmaster/Shoptask
    Last Post: 09-22-2016, 03:56 PM
  2. Replies: 1
    Last Post: 01-07-2010, 01:07 AM
  3. Extended X-Axis X2 Done!
    By Tallen in forum Benchtop Machines
    Last Post: 09-25-2009, 08:30 AM
  4. Need Quick Answer on Shoptask 1720XMTC CNC
    By gerryv in forum Shopmaster/Shoptask
    Last Post: 03-08-2008, 07:02 PM
  5. Collets for SHOPTASK 1720XMTC
    By stanger53 in forum Shopmaster/Shoptask
    Last Post: 02-09-2007, 10:33 PM
