585,764 active members*
4,132 visitors online*
Results 1 to 9 of 9
    Sep 2021
    13
    Lost dimension
    Hello
    I have a China cnc machine. Servo motors 850w syntec system. I noticed that over a long distance, a 0.5mm cut loses 2000mm and cuts in 1999. 5
    Jun 2005
    1730
    Re: Lost dimension
    Check your steps per unit it might need to be tested with a long linear scale
    Also check for backlash, you have good servos with 850w and a good control most likely minor adjustment to steps per unit
    Sep 2021
    13
    Quote Originally Posted by CNCMAN172 View Post
    Manually with a long ruler I drove a difference of 0.5mm how do I adjust the value can you tell?
    Jun 2005
    1730
    Re: Lost dimension
    Quote Originally Posted by Topgirda View Post
    I do not have a CNC unit with the Syntec controller, but it my guess is this works like most other controller. Look in your Syntec manual how to adjust steps/unit. This will almost always be a parameter. They set it by default on most systems you buy. You look at the existing number for example 41.456, then you tell it to move the length you want to test. Say 500mm or whatever works on your machine. You do this using a precision ruler so you can determine exactly how far the system actually moved. Then adjust the steps/unit number just slightly up or down and run the test again. You will get it to go the exact distance when you have the adjustment correct.
    Russ
    Re: Lost dimension
    Most time ,it should be motor pulse setup value in system .
    Sep 2021
    13
    Re: Lost dimension
    I searched for information but nowhere to find a way to change the value
    Re: Lost dimension
    From you description, you may try to adjust the Backlash Compensation value, not sure about Syntec system.
    What we use is GSK system, we can change Parameter No. 034 value to fix that.
    http://cncmakers.com/cnc/controllers/CNC_Controller_System/CNC_Retrofit_Package.html
    Sep 2021
    13
    Quote Originally Posted by cncmakers001 View Post
    Yes any parameter is a syntec system?? ????
    Re: Lost dimension
    Not sure about Syntec system, sorry.
    You might check the user manual from Syntec.
  1. X5 Dimension text
    By kolias in forum Post Processors for MC
    Last Post: 07-23-2012, 06:02 PM
  2. Dimension's Verification
    By jerrywi in forum Momus Design CNC plans
    Last Post: 02-02-2012, 01:35 AM
  3. Dimension question
    By tinman13 in forum BobCad-Cam
    Last Post: 03-20-2010, 07:44 PM
  4. Snap on Dimension
    By keith20mm in forum Dolphin CAD/CAM
    Last Post: 10-13-2009, 05:48 PM
  5. Changes to Dimension Preference
    By SPEEDRE in forum Solidworks
    Last Post: 02-01-2008, 07:03 PM
