We need information label on the Z Axis motor for Torqcut 22 Bridgeport we missing the Z Axis Motor
and where to get a replacement
I'm happy to grab the number off mine. I presume yours has been fitted with the larger Z axis drive already suited for the Parvex motor? You'll know since the Z axis drive will be a bit different design than the X/Y.
Thanks i really appreciate if you reply with the information, we send the motor to rebuild and the guy disappear with the motor, we trying to get one but we
need the motor description and the encoder, yes the Z axis motor is different from X and Y Axis
Z axis motor is with brake ,
No loss those motors usually arent rebuildable. But encoder is a small loss.
What is serial number of machine. From 1 to 120 could be SEM or Parvex, Above 120 its a Parvex. Parvex is DC brush, french or swiss, special for Bridgeport TQ22: small frame size, and high power. It is not like motor in pict, that is AC brusless probably Yaskawa. And brake is not part of motor.
Regardless very difficult get new. There is an alternate drop-in replacement from a US source. Have to look it up. You will also need an encoder. This is a standard off the self, but connector is a special for Bpt.
Bart
Here's a picture of the Parvex I removed from my machine. PM me if you're interested in purchase.
cheers,
Jim
Attachment 476764
