586,005 active members*
5,321 visitors online*
IndustryArena Forum > Machine Controllers Software and Solutions > Dynomotion/Kflop/Kanalog > Setting up first axis step/dir on KFLOP/KANALOG - No 'C'-experience
Page 3 of 6 12345
Results 41 to 60 of 109
  1. #41
    Mar 2022
    70
    Re: Setting up first axis step/dir on KFLOP/KANALOG - No 'C'-experience
    Hi Tom
    I attach the wiring, this my last wiring if you have any comment
    I try to make clear some components, when i did trace wiring on the machine i use the same page in protel 99
  2. #42
    May 2006
    4045
    I think yourPWM ON is wired backwards. OP (GND) should be connected to the - side of the opto.
    Not sure why you don't measure 5V. Is the 5V power supply on? Is Kanalog connect to KFLOP? Note if a terminal screw is not tight you can not probe with a meter on the screw.
    TK
    http://dynomotion.com
  3. #43
    Mar 2022
    70
    HI Tom
    I install kmotion 435f
    as i understand load KanalogInitialPID.mot is the first step
    configuration & flash screen then load channel
    i have seen the program, is their any that i have to edit
    like limit switch bit and any other
    if i'm right what are the next steps ?
  4. #44
    May 2006
    4045
    Yes. Don’t worry about limit switches now. Follow the steps here.
    TK
  5. #45
    Mar 2022
    70
    Quote Originally Posted by TomKerekes View Post
    PWN connect to positive
    Op (GND) connect to negative ( is this connection wrong ?)
    I said I measure the voltage but no 5 V
    Which 5V supply must be on? ( kanalog have power supply connection ?)
    5V and 12V power supply is connected on kflop
    I connect kflop and kanalog ( data cable and rj45 )
  6. #46
    Mar 2022
    70
    I can't get permission for the link
  7. #47
    Mar 2022
    70
    Hi Tom
    I attach the kanalog connection pictures
    The enable pin when I connect 6 and 8 the motor moves afew inches then green light becomes off
    I changed 6 to 5 it didn't moves green light keeps on
    Then I load kanalogInitialPID.mot in configuration screen then I go to step Response screen I select each axis and press move only command and output response but position the red line is flat
  8. #48
    Mar 2022
    70
    I'm confused on the drivers
    Depending on the manual 5,6 and 7 are connected with switch it didn't say anything about enabling
    The link that you attached before ( steps ) I can't access
    What shall I do if you have some thing to show me the way
    - - - Updated - - -
  9. #49
    Mar 2022
    70
    This are the drivers
    I read I can check or test Analog Amplifier by connecting 1.5V in series connected 1K Ohm
    I did even that with connecting those pin 6 & 8and without connecting
    And after I change 6 to 5 ( REF ON ) the motor is not turning
  10. #50
    Mar 2022
    70
    The drivers
    Attached Thumbnails Attached Thumbnails 16531426309021693703890276308627.jpg
  11. #51
    Mar 2022
    70
    Hi Tom
    I know I ask so many things and I use poor language
    I hope you understand. I straggle with this machine above two months alone
    This cnczone.com is the only way to get some support
    Today the fault that I fix makes me confused above three weeks, it was tachogenerator line was cutted inside the machine that was the cause the servo run faster and stop and also green LED off
    After I fix when I connect with kanalog it run slower and when I swap terminals ( + REF & -REF ) it run in the other direction
    Now I face the software
    I downloaded new version but window xp can't allow to install so I keep work on the Kmotion that I installed
    Can you support me what I'm going to do just steps I will figure out the details
    Regards
  12. #52
    May 2006
    4045
    Here is the corrected link, but it seems you already found it.
    Perform the steps there and post the results.
    If those are successful then perform a Move on the Step Response Screen and post the Step Reponse Screen, Config Screen, and IIR Filters screen here.
    TK
  13. #53
    Mar 2022
    70
    Hi Tom
    When I connect Amplifier with kanalog (+Ref and -Ref ) servo run slowly that cause by noise I think how can I fix ?
    And I load KanaloginitialPID.mot when I push move in step response screen only one axis move ( the axis connect JP11 pin 1 ) also in this case I change Gain to -1 the direction didn't change
    On Step Response screen andiir filters screen get like
  14. #54
    Mar 2022
    70
    And I saw your note about how can test if kflop control the X motor speed and Test if kflop can know the encoder position after wired DAC0 wired X motor amplifier,
    What is that DAC0 please make it clear?
    Is there other c program that I have to load ( before I load KanaloginitialPID.mot, I think their must be )
    I try to load init.c program and compile after I edit inti3Analog.c and I load again KanaloginitialPID.mot the same thing happens
    I have no Idea which how many c program I have load. I try to look the c programs I understand some what is written in that
    But I'm confused on where I can specify the input output ( it means Kmotion.exe have to know the hardware )
    Please try to make clear for me I'm new for this and even I haven't seen before
    I feel I did fine the wiring after that I install Kmotion.exe then I stop
  15. #55
    Mar 2022
    70
  16. #56
    May 2006
    4045
    You didn't do the steps in the link or post the results.
    TK
  17. #57
    Mar 2022
    70
    I did the initial setup for each axis that is what I get I attach pictures ( print screen on xp disturb me that is why I send by photo )
    Is their any thing that I have to do before that?
  18. #58
    May 2006
    4045
    You don't seem to be following recommended steps. Post the results from every step. Work with one axis at a time.
    Initial Setup/Testing for Analog Amplifiers
    1. There is a starting configuration for KFLOP+Kanalog called KanalogInitialPID.mot in the \KMotion\Motors folder. Load it into an axis channel from the KMotion Configuration Screen. The basic first steps are to verify the hardware:
    2. check the encoder counts correctly as shown on the KMotion Axis Screen Position (a KFLOP Axis must be configured as Encoder Input with the Input Channel0 set to the channel where the encoder is physically connected)
    3. check that the DACs can command the Amplifier to control motor speed. Test Console commands like DAC0=200 to Output ~ -1V (with the axis disabled - if any axis is enabled and continuously writing to the DAC any Console Command will be overwritten)
    4. If steps #1 and #2 above work correctly, enable the Servo using the Step Response Screen. Zero, Enable. The motor should then attempt to weakly hold position.
    TK
  19. #59
    Mar 2022
    70
    That was what I did
    I load KanaloginitialPID.mot from Kmotion motors by configuration screen load chanel
    Then I go to step response then move
    Their is something that makes me confused
    Load KanaloginitialPID.mot without locating the i/o will not impossible do
    Now the Time here is midle of night I spent above 12 hrs in this
  20. #60
    Mar 2022
    70
    Hi Tom
    I spent this week making revision on wiring and reading kflop manual
    I ask so many questions, the basic thing that confused me was the channel Bit
    Now I get some hint from kflop manual pdf
    So I connect CH0 on Kanalog JP11 pin 0 , CH1 JP11 Pin 1 in sequence. It should be like this
    If it is wrong I hope you correct me
    And I make correction in my wiring encoder connection
    I connect A & B on JP 1 and Z on JP 2
    Then first I load KanaloginitialPID.mot on configuration screen and select CH0 and I go to step response screen set CH 0 ( when I select on configuration screen it set automatically CH0 on step response screen) then when I press move CH0 it did then I have saw the encoder is counting
    Then I open again configuration screen set CH1 and open step response screen
    But when I click on move CH 1 didn't move CH 0 did
    Then I did the same thing on CH2
    The result was the same servo that I connect JP11 ( CH0 ) is moving
    The other thing is I get the bit no for JP 2 in the manual ( 152 -159 ) what about JP 1 ?
    Regards
Page 3 of 6 12345
  1. Kflop with STEP/DIR output
    By funding33 in forum Dynomotion/Kflop/Kanalog
    Last Post: 12-01-2021, 04:49 PM
  2. KFlop to step/dir spindle
    By macona in forum Dynomotion/Kflop/Kanalog
    Last Post: 01-14-2017, 09:06 AM
  3. KFlop how to configure spindle as Step and Dir No output for DIR
    By vetsen in forum Dynomotion/Kflop/Kanalog
    Last Post: 10-08-2015, 07:08 PM
  4. KFlop with KAnalog Step and Dir for Yaskawa SGDH PULS/SIGN inputs
    By DeanW in forum Dynomotion/Kflop/Kanalog
    Last Post: 05-02-2013, 08:37 PM
  5. Kflop Dir / Step setup time
    By BobKinsman in forum Dynomotion/Kflop/Kanalog
    Last Post: 11-16-2012, 12:10 AM
