That depends on the enable input requirements of the Drive. Those outputs switch to GND.can i use bit 152 -159 for the enable ?
Was the screw tight?about 5V kanalog light is on,
I use JP11 GND when i measure
Can you move the Z axis in a smooth controlled manner using Console Screen DAC commands?It is Plasma cutting machine
For Z Axis i use the proximity sensors to get its right position for cutting. It have its owen limit switch
