585,956 active members*
4,560 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Arduino > One problem about building an electronic level with Arduino
    Oct 2016
    15
    I want to build an electronic level with MPU-6050 and Arduino. I have one of my MPU-6050's mounted on a breadboard and started the example in the library but the numbers are drifting quiet a lot with the non-moving module? Today i maybe try it with an other MPU-6050.
    Mar 2015
    409
    Re: One problem about building an electronic level with Arduino
    I have no experience in using this sensor. Drifting should not be a problem if the drift is relatively small compared to the values you see when moving the sensor.
    I found this example on the internet. His values also drift somewhat. Check if yours are comparable.
    https://www.kynix.com/components/MPU...no-Pinout.html
  1. Electronic lead screw (gear box), with Arduino for lathes
    By the_muck in forum CNC Machine Related Electronics
    Last Post: 05-01-2023, 09:19 PM
  2. Problem Huanjag 1.5kw Arduino Mega y Estlcam
    By jctm in forum Spindles / VFD
    Last Post: 12-07-2020, 05:04 PM
  3. Building cnc don't know which electronic components to get
    By wayne17 in forum CNC Machine Related Electronics
    Last Post: 03-22-2017, 12:46 PM
  4. VFD electronic problem
    By kostas1 in forum Spindles / VFD
    Last Post: 09-15-2014, 04:14 PM
  5. Problem with retraction level
    By al_bundy in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 06-01-2008, 08:04 PM
