585,956 active members*
4,560 visitors online*
    1014 APC Alarm
    Have a Fanuc Robo drill T14iB with a kawatate c auto pallet changer. Been battling for days. The latest problem is once it calls for the pallet to change it alarms out. The robo drill side door opens, the hydraulic arm actuates for just a second moving the pallet just a couple of inches towards the APC then it stops and alarms out with 1014. Anyone have any idea what to look for? I have verified the few bits I do know how to check. Does anyone know what all needs to be satisfied for the pallet to go onto the APC?
    Re: 1014 APC Alarm
    The Alarm codes will be created by the Machine Builder. You'll need maker documentation to lead you. You won't find it in a Fanuc Manual.
    If this machine has sat and is filthy, try cleaning everything and verifying that the sensors are working and not soaked in coolant. One place to start.Your current problem might be the sensors on the hydraulic cylinder? Look in your Help Screen if you have one.
    I have a Kawatate Pallet System on a Mori Seiki Vertical Machining Center. Here are all the things that have to be good for it to change. I'll start in manual mode where you just want to change pallets with an M code. On my machine, M160 removes A loads B. M162 removes B loads A. Doubtful that your machine uses the same codes.
    1) All doors must be closed and door interlocks active. (That's 4 doors on my machine)
    2) The pallet in the station will have a pneumatically activated lock pin underneath the pallet. Also another sensor that signifies a pallet is present and where. (Mine uses a roller plunger micro switch, tripped by the table lead edge)
    3) MDI M160 or M162 (Your M flavor may vary)
    a) Z head moves to home position.
    b) Table moves to 3rd reference position next to pallet shutter. (A position is X 3rd/Y3rd - B is X 3rd/Y home)
    c) Pallet Un-clamp happens. (Proximity Sensor Verified)
    d) Shutter Opens (Shutter closed keyed sensor opens, shutter open prox sensor activates at full open)
    e) Pallet is pushed into pallet station. (Sensors on both pallet arm hydraulic cylinder and roller plunger mentioned earlier are activated)
    f) Newly arrived pallet lock pin activates. (Position Sensor on Pneumatic Cylinder)
    g) Pallet carrier and arm move to other pallet. (pallet A position is X 3rd/Y3rd - B is X 3rd/Y home)
    h) Pallet to be loaded lock pin retracts. (Sensor on cylinder verified)
    i) Arm pulls pallet into machine (hydraulic position sensor verified)
    j) Pallet clamps (Digital pneumatic switch verified. Including errant chip obstruction and/or failed clamp detection)
    k) Shutter closes. Keyed switch verified)
    The same thing happens in Auto Mode, except there you also need the push-button on the pallet station activated to signal ready status.
    My point here more then anything is there are a lot of motions done one right after another. Each one needing verification before moving on to the next. Any one verification signal missing, (like a FIN signal) will stop the whole process and either hang the machine or throw an alarm.
    Nothing is left to chance.
    All of these systems have to be operational. They are mostly simple sensors but they need to work. Every one of them.
    Thanks I have began checking but there is somethini Did today I dont understand and it ejected the pallet
    Unto the APC. Inside the quick nc/pallet set it
    Has a screen that says pallet 1 and pallet 2
    A number for each pallet and a mode on/off
    For each pallet. When I turned the mode for A on
    And ran m65 it went through and put the pallet in
    The apc abd locked it. It stayed for about 20
    Seconds or so and alarmed out, same apc alarm.
    Should the mode for both pallets be on?
    Quote Originally Posted by the_gentlegiant View Post
  1. 1014 alarm
    By reza79 in forum Hardinge Lathes
    Last Post: 03-12-2020, 03:47 PM
  2. Hardinge Talent 6/45 M86 1014 Alarm
    By hinshelwood in forum Hardinge Lathes
    Last Post: 11-27-2019, 01:30 PM
  3. APC Alarm
    By jorgehrr in forum Fanuc
    Last Post: 10-17-2017, 09:18 PM
  4. Replies: 1
    Last Post: 01-26-2016, 05:36 AM
  5. Machine Alarm 1014
    By chatree_w in forum Fanuc
    Last Post: 09-30-2011, 12:24 PM
