Nice machine, how old is the one you have???
What are the alarms you are seeing on the screen; each one has a meaning and should be able to find the problem by what the alarm is saying this could be hardware or software if it is software and there is no manufacture support, then you may need to do a completely new control
Mactec54
Hi
The machine is old i don't remember the exact but it 3 years plus
So today i did the wiring with the new board controller and i discover that one servo drive work well i was able to control the axis with the keybord on PC
But the other driver , when i attempt to move the axis with pc it show alarm 42 on servo driver , i stop do the controll from pc and try to do jog with the keypad on servo drive but i have a problem
The servo motor move a little bit forward when i click on button up and a little bacward when i click down button on servo drive
Any help on this issue
Video on attachmnts
well both of those codes seem to be servo overload alarms. It would not matter what control you use if one or more servos fault then you can't use the machine.
Can you identify which of the servos is faulting?
Craig
Can you try to move just one axis at a time. Say try x first, if that's OK then try z.But these alarm is when i try yo move axis x and z
Its not impossible that both servos fault but its more likely that just one is.
This would have been my next suggestion, namely decouple the servo from the ballscrews. That would eliminate any drag/mechanical lock in the ballscrews or axis assembly.I have dissamble the servo motor from the ball screw and the probleme still existe
If the fault still occurs then that suggests a fault in the servo and/or drive. If that's the case then follow Matec's idea of jogging the servos using the drive alone.
Craig
Ok perfect craig , a have done the same , the big problem is that even in jog the 3 servo drive act the same when i try to move the servo motor of course from the keypad of drive it move a little and the same thing if i try backward like it hase some limit or torque week , i don't know i have only one drive that work on both mode jog and from pc
If you can give an whatssap or email i can send you the video like that you can understand the prblm
its starting to sound like one or more of the servos are faulty.
I would suggest that you disconnect the controller I/O, that is CN1. Now any faults that occur, if any, will be the servos themselves.
You need to get access to the servo drives.
On page 4-2 of the manual you need to get the drive into 'Ad' mode, that is Test Operation mode.
On page 4-3 tells you how to change modes.
Page 4-12 and 4-13 show how to jog the servo shaft both CW and CCW.
If the servo alarms it will be displayed on the drive.
Craig
Yes, there are Parameters to set to go into jog mode, but you should be trouble shooting the alarms before you even try and do any changes to your machine.
Jogging is not going to work if you a have cable and wiring problems that all need to be checked, this includes limit switches etc. like you said you don't know what the guy that looked at it did
They are not difficult faults to check just do one at a time
To Jog look in the manual Section 6 operations Jog operation section this is where and how to setup for jogging
Mactec54
Hi Matec,
Take a holiday, I suggest Ukraine, very nice this time of year.you are not helping just confusing with your Bs,
Craig
