Originally Posted by
spitlight31
Dear Rick and dear community,
I conducted all tests in the troubleshooting sections, everything works well, including the capacitors, even the solenoid valve.
My defaults, is the measure between resistance from the work lead (J23) to the nozzle (red wires). and also the work lead, nozzle, and electrode (white wire) to ground.
The resistance measure between work lead(J23) and electrode (white wire) is correct, but when I take each one of them individually and mesure their resistance with the ground(Example: resistance measure between the work lead(J23) and the ground) I don't get an open circuit, which is strange.
I deduced the power supply needs to be changed, but because the nozzle goes to the torch, I don't know if I need to change the torch as well.
Any input would be appreciated.
Best regards,
