This is the U-TRSM company's slewing drive installation and use manual, if your equipment uses a slewing drive or slewing ring, this manual will be suitable for you.
https://en.u-transmission.com/wp-con...n-manual-1.pdf
This is a new type of rotary drive, instead of using a worm gear, it uses a spur gear, so that it can have a higher speed.
It can be used in construction machinery, lifting machinery, automated industrial equipment, municipal vehicles and other equipment. It can replace the slewing bearing structure in the equipment, and the closed design can keep the slewing bearing free from contamination, and the service life can be longer.
You can visit https://en.u-transmission.com
Or contact us: [email protected]
Get more information.
