585,956 active members*
4,576 visitors online*
IndustryArena Forum > MetalWorking Machines > Okuma > LT15 OSP7000L Can't get a program to run alarm 2477-01
Results 1 to 8 of 8
    Hello,
    We've aquired this machine and would consider ourselves beginners on lathes/Okuma controls as a whole. I've got every book with the machine and thought I'd created an extremely basic program to see it do something but I'm mistaken with this alarm code. I've attached a picture of the program and alarm in hopes someone makes me feel like the newbie I am and offers an easy fix. I have no sample programs in the machine to base anything off of but did see it run programs before we shipped it here. Appreciate any help!
    Nov 2007
    352
    Re: LT15 OSP7000L Can't get a program to run alarm 2477-01
    First find out what G110 is doing ? Someone has created that in a Sub program file ?-----------I will be in the Macro screen as G110 and linked to a program ?
    This is a 4 axis lathe with two turrets like the LU15 Was ?
    Dont need G18 not that i remeber
    Many yrs ago i worked on Cadets/Crwons/MX40/50 and Someother ones but been a while lol
    Apr 2009
    1262
    G110 is for engaging your C axis.
    First things first… you need to tell it which spindle you are working with. G140 for main or G 141 for sub.
    Do you have the manual for sub spindles for that machine?
    Best regards,
    Experience is what you get just after you needed it.
    Apr 2006
    822
    Quote Originally Posted by OkumaWiz View Post
    Best regards,
    Isn't M110 for C axis engage, With M109 for disengage?
    Been a looooooong time since I worked on a machine with live tooling.
    Brian.
    Oct 2009
    114
    Which turret with which spindle is running. You have to write these commands in first rows.
    Apr 2009
    1262
    Quote Originally Posted by broby View Post
    Brian.
    Oops! You are correct… the M vs G didn’t even register!
    I think G 110 and G111 are for which spindle G96 is active on if I remember correctly.
    Apr 2006
    822
    Yep, G110 is prioritising the upper turret when using constant surface speed, G111 is the Lower turrent priority.
    Apr 2009
    1262
    This will give you some code to chew on for a while...be careful not to bite off too much to chew!
    :idea:
  1. Okuma LCC-15, OSP7000L alarm 1206 and 1211
    By Armando V. in forum Okuma
    Last Post: 11-17-2022, 08:28 PM
  2. stopping program and opening door OKUMA OSP7000L
    By Havemann7174 in forum Okuma
    Last Post: 01-23-2014, 02:15 PM
  3. OKUMA LT15-M LATHE 1309-13 Alarm A
    By energyzer in forum Okuma
    Last Post: 03-30-2012, 01:16 AM
  4. need program for okuma lb-15II. osp7000L.
    By DK-Alexz in forum Okuma
    Last Post: 08-16-2010, 04:52 PM
  5. Okuma LT15 - OSP7000L HELP.
    By tunitime in forum Okuma
    Last Post: 05-01-2009, 08:51 AM
