585,700 active members*
4,258 visitors online*
Results 1 to 8 of 8
    Jan 2022
    107
    Using Analog Input AUX
    The MK3 is equipped with analog inputs, but I have some problems using them.
    I know it is easy to use a poti, connected to GND and 3,3V and connect it to AUX2 for example. But in my situation I have a infrared temparature sensor which has an analog output 0-10V.
    So i thougt would be easy: Using two resistors to create a voltage divider between the 0-10V signal and GND to get an voltage output of 0-3.3, but it looks like I have some problems with the voltage reference and even if i directly connect the 0-10v to AUX, i can not use the full range of the AUX input.
    Measured to ground I have had 3.3v on the AUX, but the display showed only a low value. Connecting the AUX to the onboar 3.3v, it shows maximum value. That's why i think the AUX may have a internal voltage reference which is not directly related to the GND or the Infrared sensors 0-10V output has some unknown behavior.
    Is somebody using the AUX in for 0-10V measurement and can suggest how to connect it properly?
    Jan 2018
    1516
    Quote Originally Posted by awpross View Post
    Well. The user manual states:
    AUX connector is "reserved for future use".
    Whatever that means.
    You may need to look at the EXT/in and EXT/out expansion boards for the EXT headers not AUX.
    Jan 2022
    107
    Re: Using Analog Input AUX
    The user manual has not been updated since 2014.. the mk3 controller has menawhile 2 red ext connectors and 1 red canbus adapter with two jumpers which has nothing to do with the manual from 2014...
    So the "future use..." on aux connector is outdated
    The Ext in and Ext out does not support analog. But the aux connector does.
    The documentation is just behind the actual progress of the MK3 Hard and Software... Personally, i miss detailed descriptions of the connections, but I understand that problem. I am a software develloper and I know the problem of beeing behind with documentation.
    Especially the in and outputs are rarely documented and the existing descriptions are just covering the very basic connections.
    Mar 2017
    1304
    "reserved for future use" means, that we planned add-on board for this (analog joystick) but then we decided on different solution.
    Be careful because these pins are not protected and main processor can be easily damaged.
    Jan 2018
    1516
    Quote Originally Posted by PlanetCNC View Post
    Sort your documentation please.
    Many scrutinise pdf docs before deciding on hardware selection.
    So called "2 analoge inputs" are non existent and any wiring "mishaps" should be on planetcnc's head.
    Every other non planetcnc controller I look at have issued up to date revisions on a regular basis.
    Jan 2022
    107
    Sounds like a good idea to provide any infos to use the aux connector for analog input and develop an ad on board which adds safe support for analog input.
    common analog input would be 0-5V / 0-10V / 4-20mA
    I do not have any experience with optocouplers but i am sure with the right knowledgement it would be possible to use it for isolation of the analog input. It may not be required to have perfect linearity, that could sure be compensated internally by scripts.
    I already found a good circuit example which was originally designed for arduino but thats not a module who could be bought somewhere: https://www.electronics-lab.com/proj...le-for-arduino
    I don't know how to rebuild the example. Seems to be expensive for a single piece.. maybe it could be adapted to the MK3 and then provided as addon for MK3??
    Jan 2022
    107
    Do You think the attached circuit may be sufficient to protect the analog Input?
    I have no knowledge of the internal circuit of the MK3s AUX IN, so this is very theoretically..
    The shotkey diods are for preventing lower than GND and higher than 3.3V ref. Found that on some examples. With that, the max voltage would be aprox 3.6 Volts and the lowest -0.3V caused by the shotkey voltage drop.
    The 10nF capacitor should smothen the signal.
    The 10k resistor should reduce current in case of over or under-voltage.
    In case of over-voltage. For example 24V directly on the 0-10V output, the max current through 3.3V connector should not exceed -0.5mA with that circuit. Don't know if MK3 can handle that but seems better than having 8V on AUX IN in case of miss wiring.
    Don't know if the GND of AUX connector is the same than GND of the Power Supply of the MK3.
    Jan 2022
    107
    I have now a working solution for using AUX as Analog Input.
    It's not the cheapest solution, but industrial style with a 3-way isolated Signal converter like Weidmüller EPAK-VI-VO 7760054175
    There are different converters available for 4-20mA and 0-10V
    The Output is fully isolated and directly supplies 0-10V. With a simple voltage devider, it could be used as 0-3.3V for the AUX input.
    Because of the 3-way isolation, powersupply is also isolated from input. So you can adapt the input to different situations.
    There is no additional protection of the AUX input necessary because the output is already limited, filtered and protects the output up to 2500 Volts on input or powersupply.
  1. Current Transformer to Analog input?
    By mmurray70 in forum Dynomotion/Kflop/Kanalog
    Last Post: 11-29-2020, 07:17 PM
  2. analog input
    By dbunyip in forum Viper Servo drives
    Last Post: 11-01-2016, 11:31 PM
  3. Coolant to aux port but no power to aux. ports, need help!
    By ballistic42 in forum Benchtop Machines
    Last Post: 02-15-2015, 08:08 AM
  4. Problem with Analog Input mode
    By speedydumpster in forum CNC Machine Related Electronics
    Last Post: 05-14-2012, 07:03 PM
  5. How to drive Analog Servo Input +/- 10V
    By gurvy in forum CNC Machine Related Electronics
    Last Post: 05-31-2007, 05:31 AM
