585,992 active members*
5,878 visitors online*
    Jul 2007
    189
    Help identifying carbide insert
    I recently got one of the Chinses mini lathes
    A buddy of mine gave me a bunch of turning tools
    I use mainly HSS and grind shapes so I am new to carbide inserts
    He gave me a small boring bar that fits my quick change tool post
    It is missing the carbide insert and the 3mm screw
    Can anyone help me to figure out what type of carbide insert to buy that fits this boring bar?
    I do mostly soft stuff like plastics and Aluminum and some very light steel machining
    This web page was some help identifying shapes
    https://www.mitsubishicarbide.com/en...identification
    It is a Rhombic shape and I measured 80 degree
    So it looks like C in the chart in my screen shot from that web site above
    I measured 8mm wide on the tool surface where the side of the insert side would be
    But if the insert sticks out past the edge of the tool, would the insert be a 8 mm side measurement or 9 mm side?
    Measurements in my image below
    80 degree angle
    8mm side
    9mm diagonal side to side
    11mm diagonal length but probably 10mm not counting the round back area
    2mm height in the tool cutout pocket
    Any help here is appreciated
    Jul 2007
    189
    Re: Help identifying carbide insert
    edit, I may have posted this in the wrong board
    I just saw the metal work tooling board
    Admin, you can move this if it needs to be moved?
    Mar 2015
    47
    Greetings,
    Does the bar have any identification on it? This will quickly determine the correct insert.
    Cheers,
    Dave
    Jul 2007
    189
    Hi Dave,
    No it is a plain round bar with no marks
    Jul 2007
    189
    I gave up on this boring bar.
    I ordered a set of 4 bars different sizes for $17 on Ali express
    It comes with 10 inserts and 4 bars
    6/7/810mm boring bars
    https://www.aliexpress.com/item/1005...21ef1802BRP14X
  1. help identifying turning insert
    By ndrew2505 in forum Metalworking- / Woodworking Tooling / Manual Machining
    Last Post: 05-03-2012, 01:18 PM
  2. Carbide Insert Question
    By MotoDan in forum CNC Tooling
    Last Post: 02-27-2012, 09:33 PM
  3. carbide insert lingo
    By Dancy in forum CNC Tooling
    Last Post: 12-13-2011, 09:40 PM
  4. Carbide insert Tooling
    By mae1479 in forum Haas Mills
    Last Post: 09-30-2009, 10:27 PM
  5. Carbide insert designations
    By mikehg1 in forum Uncategorised MetalWorking Machines
    Last Post: 06-29-2008, 04:08 PM
