ACCTEK fiber laser cutting machine is widely used in manufacture billboard, advertising, signs, signage, metal letters, led letters, kitchen ware, advertising letters, sheet metal processing, metals components and parts, ironware, chassis, racks & cabinets processing, metal crafts, metal art ware, elevator panel cutting, hardware, auto parts, glasses frame, electronic parts, nameplates, etc.
The Advantages Of ACCTEKGROUP Fiber Laser Cutting Machine1) Excellent beam qualityThe focused spot smaller cut lines more sophisticated, higher productivity, better quality and processing.
2) High cutting speed
2 times faster than the same power CO2 laser cutting machine.
3) High stability
Adopts the world's top imported Fiber laser, stable performance, a key component of up to 100,000 hours life.
4) High electro-optical conversion efficiencyFiber Laser cutting machine is three times higher than the CO2 laser Electrical and optical conversion efficiency, energy saving and environmental protection.
5) Low cost
The whole power consumption of only similar CO2 Laser cutting Machine 20-30%
6) Low maintenance costNo working gas lasers; optical fiber transmission, without reflecting lenses, can save a lot of maintenance costs.
7) Easy operation and maintenance
Optical transmission, no need to adjust the optical path.
Main Parts
Option
Specification
Model AKJ1530F1
Working area 1500*3000mm
Laser power 1kw/1.5kw/2kw
Control System Au3tech
Transmission Taiwan rack and pinion
Guide rail Taiwan Hiwin linear guide rail 25mm
Motor Taiwan Delta servo motor
Electronic Components French Schneider
Max Speed 20m/min
Repeat positioning accuracy ±0.02mm/m
Maximum Acceleration 0.5G
Min line width 0.1mm
Graphic Format Supported AI, BMP, DST, DXF, DXP, PLT
Cooling Way Water cooling
Machine Operating temperature 0 ℃ -40 ℃
Power Requirements 220V 1PH, 50Hz/60Hz
Product Application
The ACCTEKLASER fiber laser cutting machine is suitable for metal cutting like stainless steel sheet, mild steel plate, carbon steel sheet, alloy steel plate, spring steel sheet, iron plate, galvanized iron, galvanized sheet, aluminum plate, copper sheet, brass sheet, bronze plate, old plate, silver plate, titanium plate, metal sheet, metal plate, etc.
