585,996 active members*
3,850 visitors online*
IndustryArena Forum > CAM Software > Autodesk CAM > 2D Contour missing the edges completely....
Results 1 to 6 of 6
    Mar 2021
    6
    Hola
    For some reason my contours all look good across the middle when I simulate, but you can see here with my stock turned on the edges of the X-axis are missed completely.
    I'm new to CAM in Fusion 360, so I expect I'm missing something obvious.
    Thanks in advance for any input.
    Jan 2018
    1516
    Play with Setup settings: is it set cutting outside stock?.
    Can be a little trial and error finding your ideal setup.
    Are you highlighting the cutting area or just the line?.
    If trying to cut the recess out you want to select the inner step rather than the stock edge.
    For edge recesses I normally use slotting with ramping rather than contour.
    Mar 2021
    6
    Re: 2D Contour missing the edges completely....
    Quote Originally Posted by dazp1976 View Post
    I have the edges selected for all of the slots, and they all cut correctly except for the edges. I guess I could add those edge 'rabbets' as a slotting operation?
    Dec 2003
    1225
    Are you viewing the part,rather than the stock?I know nothing of Fusion CAM but the other systems I have used allow you to specify a stock model that is a little larger than the actual part model and this allows you to view the excess material being removed when you run the simulation.
    Jan 2018
    1516
    Look at the heights tabs as well.
    If you want to skim an edge at full depth you need to tell it that for the particular operation.
    Also the "stock top" "model top" "stock bottom" "model bottom" select boxes have dumb defaults and messes heights up relative to cut depth.
    Mar 2021
    6
    Cool Re: 2D Contour missing the edges completely....
    I added facing operations for just the edges. Had to make them separate because I guess you can't choose 'from other side' on 1 face and not the second.
    Thanks for your replies!
  1. 2D Contour missing the edges completely....
    By tuanifab in forum Avid CNC
    Last Post: 03-07-2022, 02:37 AM
  2. SolidWorks HSMWorks toolpath cutting through contour during 2D Contour roughing pass
    By viaae1 in forum SolidCAM for SolidWorks and SolidCAM for Inventor
    Last Post: 07-28-2021, 09:38 PM
  3. Laser cutter producing dotted line cuts edges are very rough even when cut completely
    By worldspawn in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 04-29-2020, 05:13 AM
  4. Z-axis problem: missing steps - tried everything, completely lost
    By cncvirgin in forum Stepper Motors / Drives
    Last Post: 09-24-2014, 12:56 PM
