https://www.youtube.com/watch?v=4CxbNz969LA
Product link:
https://www.automationtechnologiesin...-90w-130w-180w
Integrated Servo Motors are 57mm frame sized brushless integrated motors with a 16-Bit encoder and a servo drive. Very compact size with all components integrated. This kind of motor save mounting space, eliminate encoder connection & motor wiring time, and cut/reduce cable and labor cost. RF-interferences are substantially reduced.
Step & direction command input for position control
Compatible mounting Size with 57mm stepper motor
Smooth motor movement and excellent response time
1: High position accuracy
2: Isolated control inputs of Pulse, Direction
3: Current loop bandwidth (-3dB) 3.5KHz
4: Speed loop bandwidth 650Hz
5: Position loop bandwidth 300Hz
6: Communication with PC via RS232
7: Easy to tuning for CNC application with Protuner software
8: Low torque-ripple with state-of-the-art design of magnetic circuit (low cogging torque)
One year warranty
