585,996 active members*
4,502 visitors online*
    Jan 2021
    12
    Ball Screw Cover?
    I need a way to cover my ball screw to keep debris out. Any suggestions?
    Not sure why the picture comes out sideways, it doesn't on my desktop.
    Nov 2020
    361
    Re: Ball Screw Cover?
    if you want something professional check krius https://krius.en.alibaba.com/
    Jan 2018
    1516
    Quote Originally Posted by remotecaptures View Post
    If you go to Aliexpress and search for these terms:
    Concertina cnc bellows,
    Way cover bellows,
    Milling way cover,
    Accordian way cover.
    You'll get a few ideas and maybe even see exactly what you want. I found one suitable for my mills Y axis.
    On my mill Z, anything too thick would impede travel so I modified a car window roller blind using some 0.5mm nitrile sheet. Got the idea from a video of a G0704.
    Thickness not so much an issue with a router.
  1. Double ball nut worth it for long C7 grade rolled ball screw?
    By salukikev in forum Benchtop Machines
    Last Post: 09-02-2021, 07:48 PM
  2. Play in ball screw with anti backlash ball nuts
    By chesty012003 in forum Linear and Rotary Motion
    Last Post: 08-20-2021, 07:27 AM
  3. Replies: 8
    Last Post: 11-26-2013, 06:22 PM
  4. 6030 spiral ball screw cover
    By 5th-axis in forum Fadal
    Last Post: 11-19-2010, 04:28 PM
  5. Ball screw cover
    By Riverside192 in forum Bridgeport / Hardinge Mills
    Last Post: 10-15-2010, 03:30 AM
