585,930 active members*
3,918 visitors online*
IndustryArena Forum > OpenSource CNC Design Center > Arduino > A problem about using an arduino to controll motor
    Oct 2016
    15
    I'm trying to use 28BYJ-48 stepper motor with ULN2003 driver Arduino, i.e. move an object in one direction for a short time and then reverse it and then do a repeat while the power in still on. I have made lots of stuff (electronic clocks mainly) but this the first time I have used an arduino controlled motor. I do have a question. Normally I solder my connections but with the UNO board that does not seem to be necessary. Is that correct?
    Mar 2015
    409
    Re: A problem about using an arduino to controll motor
    You can use dupont cables to connect the uno.
    https://nl.aliexpress.com/item/40002...rch-mainSearch
    There are also breakout headers for the uno having screw connections.
    https://nl.aliexpress.com/item/10050...rch-mainSearch
    The Arduino nano has the same Atmega 328P processor and has a smaller foot print
    You can make dupont cables your self:
    https://www.amazon.nl/JZK-krimpgeree...19011825&psc=1
  1. Use co2 laser machine controll card to controll 30W fiber source
    By oneeye in forum Laser Control Software
    Last Post: 06-12-2020, 05:23 PM
  2. Replies: 1
    Last Post: 03-20-2017, 05:47 PM
  3. G0704 motor controll board help.
    By joemusso in forum Benchtop Machines
    Last Post: 05-14-2016, 07:49 PM
  4. Replies: 2
    Last Post: 03-26-2014, 03:15 AM
  5. PID controll of R\C Brushless motor!!
    By tskguy in forum DIY CNC Router Table Machines
    Last Post: 07-02-2011, 08:51 AM
