585,567 active members*
3,406 visitors online*
IndustryArena Forum > Laser Engraving and Cutting Machines > Commercial Laser > G.Weike Laser > Laser comes to almost a complete stop and then starts cutting a slow horizontal line
Results 1 to 2 of 2
    Apr 2012
    21
    Sometimes the file will cut just fine and sometimes it will be going through the cuts and I notice the laser head stop moving in the middle of the job. I go and take a look and it actually hasn't stopped cutting.....it is actually just cutting a horizontal line at a VERY slow speed at the max power I set for the job. Have had a few small fires to put out because of this. (reminder....never leave your laser running unattended) This drives me crazy cause it ruins the piece of acrylic I have in to be cut. This doesn't happen every time I run the same file. Just occasionally it will do this. I can open the file and it will work fine. Other times it does this. Any ideas?
    Feb 2024
    41
    Re: Laser comes to almost a complete stop and then starts cutting a slow horizontal l
    It sounds like you're experiencing inconsistent performance with your current laser cutter. Have you considered trying out Monport laser systems? Monport lasers are known for their reliability and consistent cutting performance. They offer easy-to-use interfaces and high-quality results, helping you avoid issues like the ones you're facing. You can explore Monport laser products and see if they meet your needs at https://monportlaser.com/?sca_ref=5031521.ka374VZjm3.
  1. Huanyang GT Inverter Starts but doesn't stop
    By TTalma in forum Spindles / VFD
    Last Post: 01-01-2019, 09:29 PM
  2. Newbie Needing Help Please. Laser Engraving cutting a Wavy line?
    By Grimreaper831 in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 09-07-2015, 11:03 PM
  3. Laser cutting ends dont exactly meet in the same line
    By udm in forum Laser Engraving / Cutting Machine General Topics
    Last Post: 01-24-2015, 10:41 PM
  4. Stepper Motor Starts and Stop
    By crodriguez1517 in forum Stepper Motors / Drives
    Last Post: 04-30-2012, 03:39 AM
