585,581 active members*
3,630 visitors online*
    Mar 2022
    Amada RG-80 with Hurco Autobend 7
    Hi ppls, not sure if I'm posting in the right section
    Using an Amada RG-80, I don't have that much time on it, but it seems like a good machine
    One problem, it's an Up-acting lower beam machine... I can't seem to set the lower limit setting with the lever on the front of
    machine....When the lower beam is at a height that is more suitable for parts being bent I'm assuming I push the lever to the down position
    The problem is it doesn't seem to do anything, the lower beam goes all the way to bottom stroke
    I can set the speed no problem with the other lever in behind it but I would like to get that low limit lever working
    Any thoughts?
    Thanks, Bill
    Mar 2022
    Re: Amada RG-80 with Hurco Autobend 7
    Almost forgot about this post
    It was an easy fix... pulled the front cover off and lubed some parts that lock the height in place
  1. Hurco Autobend 7 Control Relays
    By Lomach in forum HURCO
    Last Post: 04-12-2016, 08:58 AM
  2. Replies: 0
    Last Post: 01-19-2015, 05:54 PM
  3. Hurco Autobend 7 Y-axis manual jog limit
    By Marankie in forum HURCO
    Last Post: 01-08-2015, 09:26 PM
  4. Cincinnati brake press hurco autobend 7
    By jamesbond007 in forum Bending, Forging, Extrusion...
    Last Post: 06-11-2010, 05:50 PM
  5. Hurco autobend 7
    By ocean toad in forum Bending, Forging, Extrusion...
    Last Post: 04-12-2010, 05:00 PM
