586,000 active members*
4,834 visitors online*
IndustryArena Forum > Events, Product Announcements Etc > For Sale Only > Rye MG2400 Twin Head CNC 8ft by 4ft
    Dec 2014
    i hope this is ok for me to post here.
    we are currently trying to get rid of our Rye MG2400 Twin Head CNC 8ft by 4ft, its been very reliable for us over the 13 years we have ran this machine but unfortunitly it has developed a fault on the X-Axis where the auto greeser failed and caused the bearings to gouge the rails resulting in juddering that if ran at full speed gives a overload error.
    as this machine is no longer needed as we have upgraded to a newer machine.
    Machine set-up as below:
    2no. Perske 4.8Kw (17,500 rpm) spindles (Manual tool change). both very good condition with smooth rotation
    2no. Pneumatic Drillings Heads (Manual tool change).
    Bed Size: 8 Ft x 4 Ft.
    Comes with operation & programming manual
    Upgraded control system by CNC support.
    VACUUM PUMP NOT INCLUDED
    https://www.ebay.co.uk/itm/RYE-MG2400-8FT-BY-4FT-Flatbed-CNC-SPARES-REPAIRS-ONLY
    Ryan
    Feb 2008
    482
    Re: Rye MG2400 Twin Head CNC 8ft by 4ft
    i have the parts for repair for this.
    however. its worth way more than 500 if you weigh it in! due to weight and scrap prices.
    strip the heads and motors off it and get it collected by scrapyard :-)
    so much to learn, so much to pass on.
    1225
    I know a man less than 25 miles from the OP who has the rails and the ability to repair the machine.The more relevant question may be"who wants a machine made by a company that went out of business more than 20 years ago?".Program loading by floppy disk was still current then.
    Feb 2008
    482
    Quote Originally Posted by routalot View Post
    they are probably the best frame that was ever made on a router. i have one in my garage at home. uccnc conversion and running on single phase its a fantastic bit of kit. especially if you buy it at scrap money. bare frame weight is around 5 tonne. i saved mine from its trip to the scrap yard after the bosch controller failed.
    Dec 2014
    yes the fact they went out of business is our man concern also parts becoming a problem as we have 9 other machines on site its not worth our time to rectify this machine. also this has been setup to be used with a network for file transfer but only works with an XP PC
  1. Replies: 1
    Last Post: 06-05-2021, 02:04 AM
  2. Rye MA154 CNC
    By ryema154 in forum Commercial CNC Wood Routers
    Last Post: 03-05-2020, 02:37 PM
  3. 4ft x 8ft CNC Driver X & Y tables - need help!
    By RX7_LS7 in forum DIY CNC Router Table Machines
    Last Post: 10-10-2015, 04:56 PM
  4. Panel saw that will cut 4ft x 8ft sheets
    By Router Lady in forum Want To Buy...Need help!
    Last Post: 09-18-2008, 05:09 AM
