586,000 active members*
5,036 visitors online*
IndustryArena Forum > MetalWorking Machines > Mori Seiki Machines > Mori Seiki lathes > SL-300 (1998) Alarm EX2058 safety circuit
    May 2019
    10
    Exclamation SL-300 (1998) Alarm EX2058 safety circuit
    Hello
    Have done a lot of search/trace . but the last relay of the saf module will not com .
    Have changed All relays in safety module . saf module have 6 led's .But cannot figure out why the last relay (Y8.0) is not coming . It seems to be a loop that the setting is actually dependent of that the relay itself operates...
    if anyone wants to help , I have doc on ladder/PMC prog (ladder) / el diagrams ..
    best regards
    Ulf
    May 2019
    10
    Re: SL-300 (1998) Alarm EX2058 safety circuit
    Found that there where a combination of bad contact on the safety relay , and the nc contact on the KM1
  1. alarm EX2058
    By ponnapeou in forum Mori Seiki Mills
    Last Post: 12-05-2022, 01:53 PM
  2. Alarm 160 1998 Haas VFE
    By alpydawg in forum Haas Mills
    Last Post: 08-05-2018, 07:06 PM
  3. Improving Centroid Acorn reference safety circuit
    By pfmcnamara in forum Centroid CNC Control Products
    Last Post: 04-26-2018, 04:42 AM
  4. DISABLE SAFETY CIRCUIT
    By charlybur69 in forum Haas Mills
    Last Post: 06-06-2017, 04:27 AM
  5. VF-1 1998 alarm 179
    By joanpim in forum Haas Mills
    Last Post: 03-26-2009, 07:48 PM
