Hello
this error occurs when I want to generate the g code
can you help me ?
Hello
can you help me ?
You need to see line 3708.
you can give me more details ?
In sufficient GPP file is a problem with this line. Maybe just needs to be disabled if the G code looks fine though the error occures.
g code is not generated
Can I be more specific on how to fix this problem?
Gcode is not generated if u press cancel. If u press ok when the error occures it will be generated anyway. With or without wrong lines.
Anywhay can U show what line 3708 in MT_Nakamura_NTRX300L_Fanuc31i_XZYCB_BS.gpp looks like?
line 3708 does not exist in the gpp file
Lines are not numbered. U need to look at status bar in notepad.
I found the line
see the picture below
Try putting ; in front of this line. Looks like problem with procedure get_tool_dir_in_station. Maybe it isn't defined, or missing variables.
Quite probably it won't harm g-code, or maybe not in every case.
thx
I managed to put ";"
now the error below appears see the pictures
